hesutton
The Anti-Anderson
Yeah, I'm pretty used to working in tight, dark, and sometimes dirty spaces.
Heath
Heath
. but put me down for a timing sessionHe replaced it with one of those funny sounding 6 cylinders.
If you want your truck timed..........please do the following:
-Open your hood as soon as you get back to the campsite to let the engine heat out.........it will be too hot for Mel to work on otherwise.
-Make sure you can insert the chuck end of a 5/16" drill bit fully into the upper crankshaft timing port a full 1" (until it touches the crankshaft damper). I'm afraid he may have to turn away any truck that hasn't had this proceedure done.
Heath
what do you mean by the drill bit procedure? where does it need to fit?![]()
Like This:
