Manual glow plug switch amps.
notenuftime
Pennsylvania
Hey everyone, I'm about to wire up a manual GP switch and was wondering how many amps my switch should be rated to? Going to pick one up this week and appropriate wiring and fuse.
The_Josh_Bear
Western WA
The switch carries almost no amperage itself as its only triggering the stock relay. They are pretty much all 15a or higher so anything is fine. It might draw 1-2a but I've never measured.
Just make sure it's a momentary switch! That way it cannot be turned on accidentally or by a person that doesn't know what it's for, etc.
Cubey
Van dweller
I put a small plastic momentary switch from O'Reilly on my F250's 7.3 style system. Used 14 or 16 gauge wire, can't remember which.
Farmer Rock
Glen Rock,PA
I would recommend a 15-20 amp brass push button switch. Mostly for the better quality of those switches over the smaller low amperage switches. Like has already been said, it is very low amps at that point.
Rock
Farmer Rock
Glen Rock,PA
I think I used a 15 amp fuse. 10 should work too. I just went bigger for the switch I had.
Rock
Cubey
Van dweller
6.9 GP systems (except in 87) use positive to activate the relay if not mistaken, and 7.3 take ground. I might be remembering wrong though.
Big Bart
Tow&Slow
Newport Beach, CA
Many also set up so the switch is supplying ground to the solenoid. (Less chance for grounding out. Can pull a ground off just about anything metal in the cab.) Then supplying 12v pos directly to the solenoid when the key is in the on position.
Cubey
Van dweller
So you saying I don't need a fuse in the line?
If you wire it up the way I did, then no. Fuses are supposed to be on positive.
Big Bart
Tow&Slow
Newport Beach, CA
The 12v positive to energize the solenoid should be fused if you run direct to battery, Cubey is suggesting a 5-10amp fuse for the switch should be fine. Now fusing the +12v for the glow plugs takes about 200amps according to some, but your truck is already supplying that fused power for you.
Farmer Rock
Glen Rock,PA
My understanding is that they short to ground. I wired up 2 7.3 systems this way(both 87 6.9s). One side of the switch is hot, the other is ground. When you push the switch it creates a short. I ran the hot wires right off an auxiliary fuse block, and the ground wires to the frames.
Rock
Cubey
Van dweller
Rock
As I recall, I just ran ground through a momentary switch to the proper connection on the relay, with the one from the controller disconnected so it was reversible by just redoing the connections.
RustyNail351
