This makes for an interesting sideline discussion because there was an article in one of the lube industry magazine a few years ago about carbon, soot and oxidation byproducts building up on the cylinder wall and causing increased oil consumption. The surface isn't smooth and all this gunk builds up and kind of "glazes" the cylinder wall (for lack of a better term). It comes with engines that are run cold all the time and don't get worked. My Farmall (Neuss D358 engine) had that problem. When I bought it, it had spent more than 10 years previous doing easy stuff. The D358 is a very low compression DI diesel (15:1 CR), so not only is it a bear to start in cold weather, it doesn't warm up much when idling or not working hard and is a known slobberer (white smoke and cylinder wall washing). Even though the guy I bought it from had recently changed the oil, it smelled like diesel fuel. I bought it as a tillage tractor, so immediately I put it to work with a 9-shank chisel plow. I went through GALLONS of oil. I really thought I had made a fatal error buying that tractor (I did, but that's another story not related to the engine ( : < ). I changed the oil (to Rotella-T ( : <) and consumption decreased but not enough right away. It took about a season for oil consumption to decrease to a reasonable level and the following season, it got even better. I was scratching my head until I read that article that explained it. IIRC, I think I went through about 3 gallons in 20 hours of running that first season. Now, it uses about one-to-two quarts in a full 50-70 hour season. I should add that the engine has 8300 hours.
