Loss of power when driving
jleups
Langley
Hey everyone,
Having some issues with my truck. Its a 1992 f250, 4x4, e40d. I tried to drive it on the weekend and found it was having trouble starting and holding an idle. I then found an air leak from one of my injectors. I replaced said injector and it now starts fine and runs, the only problem is when I'm driving I have a noticeable loss of power and it pours out black smoke whenever I get into the throttle. . It also sounds louder and seems to have more of a clatter than usual. I took her out for a good drive to get any air that might have been in the system out and that didn't help. Any ideas would be great. Thanks.
Josh
Ugly Moosling
Lancaster, PA
Where did the replacement injector come from? If the smoke and clatter came after the injector replacement is suspect a bad injector.
matt-jenkins
Canada
Fuel pressure when measured off the Filter head should be between 4-7psi correct?
