Long cranking to start when hot
bdemutis
Pa
Yeah, hopefully.
Hpop isn't something I'd cheap out on.
Sent from my SM-G900R4 using Tapatalk
Well I just hope it's not the hpop I was planning on doing glow plugs and injector o rings along with new valve covers and wires.
bdemutis
Pa
Did you ever try checking the hpop oil level when it's not starting?
No because the hpop res screw is stripped off inside the res and I didn't want to break the res trying to extract it.
bdemutis
Pa
Oh boy.
Got all kinds of fun going on. Lol
Yup and today my wheel cylinder broke and then I bled the brakes and the pedal gets nice and hard then goes to the floor yay I get to replace the master cylinder. Also the ignition cylinder broke all the pins got jammed and it wont turn.
bdemutis
Pa
That would be it.
No I didn't bleed that because it looks so crusty that I was worried about braking it. But I get a nice heavy stream from each wheel. I can tell the master cylinder went because you can pump the pedal and you get brakes but then it slowly goes to the floor. Also isn't it the ABS hydraulic unit?
Yeah, I've had that, but it wasn't the master.
The rabs valve itself could still have air in it.
Whatever master you get, make sure to bench bleed it really good.
Seems it's kinda hit and miss between replacement brands. Iirc, most have better luck with "new" over "rebuilt."
bdemutis
Pa
Maybe I'll try bleeding the rab first. But I have to pump the brakes then I get good pedal then I'll hit them and it slowly falls.
bdemutis
Pa
Also make sure the rears are adjusted good.
I have to do that because the e brake isn't working so I have to adjust it tomorrow after work I'll adjust them.
Edit: Thanks for the info I just read that could be a cause of loosing pedal slowly.
Staff online
