Diesel JD
I went to a new local diesel shop today just to meet the owner and try and see how his knowledge was on IDIs. He seemed to know Stanadyne pumps real well and have good knowledge of the platform, but he said some things that sort of disagree with what I read about here. He said that anyone who tries to sell you a "turbo" injection pump or "built" pump is likely either BSing you or perhaps the pump is only for racing applications,a nd is most likely lining his pockets. Also he said that a 92.5 and later turbo cal pump is not at all right for a 6.9 even with a turbo. Something about it being not balanced right and everything. He said a slightly turned up DB2 will flow more fuel than the injectors can handle, and that the cam ring is the limiting factor on DB2s. Anyways...just thought I'd pass this along....does anyone know what Ken does to his turbo cal pumps to make them better than stock...if you read this you can answer, without of course getting into anything that is proprietary. He also said that timing with tools was sort of a waste of time once you have an ear for it and that about 40% of these trucks you can't even get a timing meter to read. Any thoughts on this? Have a good one.
J.D.
J.D.
