within 100 psi on new is good, the springs will take a set and change in 5 to 10k then if they are reset they hold for a long time. Usually.
The ice on top of the snow is ok. It will offer some traction as it breaks & packs down into the snow unevenly. You just just don't want it UNDER the snow.....bad news.Ok. We have 10" of snow here in central North Carolina and it has pretty much shut down the entire state, I know we are sissies but I'm not driving the 26ft beast with 5-6 inches of snow on the streets and a 1/2 inch layer of ice on stop the 35 mile one way to work in 15 degree weather.
Find an injrctor pump rebuild shop. They usually have the shims... A 1 thousands shim is what you looking for. Do not install this injector back in the motor unless all the other injectors pop at or near the same pressure. If others are poping at 1400 (which is the low factory limit) and the rebuilt one is opening at 2200 you will have a real big problem. The low cylinders will be timed alaike and the high pressure cylinder will be really retarded in timing... That wont run right and over time will hurt mileage and the motor...
Well I am striking out on shims. My local diesel pump/injector rebuilder just wanted to sell me injectors, not shims. If I can't find anything then I guess I will be salvage yard bound, grabbing all of the IDI injectors I can find for the shims.
