lets see those sweet IDI's
my85ford
caldwell idaho
well got mine running today and washed it and took some better pics today!
heres the pics
88beast
pa
benton its in the works now bieleve it or not currently im in the process of freeing up the wheel well space to get a manifold made
i will have to cut some of the wheel well but it will be replaced with heat tape covered metal
i plan to start out around 12 psi and dont go higher but it will get up to 17 pretty quick but with a 6.9 easily found in my local yard for cheap i plan to rebuild it and run low comp and some good stuff and then swap into the truck
then freshen up the stroker motor and put it in something cool
but all but the turbo is long term
alienturtle
Human
Ripon, CA
about 1 1/2 tons of scrap metal i haul for the high school. :sly
88beast
pa
88beast
pa
heres so far what i have
the turbo its self holset hx35 21cm housing 17psi wg
engine bay with some stuff moved around
im doing a g31 setup on the drivers side to make tons of room
also i have all the piping im going to start non intercooled for now then add one when i can afford one or find one cheap
bumper has that big flat spot in center it will be cut out and replaced with expanded metal for air intake for the intercooler
then i will do a cowel induction scoop to feed it
88beast
pa
to make the room i removed my power inverter and will relocate it to the toolbox
also i swapped heater boxes for the non ac unit
and moved the rest of the crap on that fenderwell along with moving the wiring harness
hopefully tomorrow ill mock up my tubing its supposed to be like 80 out ill take pics of that too
rjjp
Needs to go test
Clare, Mi
The day I bought it off my dad:
Last fall in the backyard:
Lately it's found itself hooked to the twin axle a little bit, I need to find an excuse to hook up to the tri-axle and a real load, hasn't actually towed anything heavy since the turbo install, and I'm itching to see how it does.
phazertwo
Die Summer DIE!
Crawlorado!
This thread makes me want a CC with a cummins in it REAL BAD..
Here is my oil burner for the time being. Hauling my buddys "crawler to be" when he moved.
I plan to leave the truck itself completely stock. It pulls trailers, and that is it! I do however dream of rebuilding the engine, studding the heads, and making 20lbs of boost!
Most likely it will get A IC, moose pump, and misters at some point, but until then :cheers:
PZ
Big Bear
