Suleiman Saadeh
I'm replacing the head gasket due to some starter fluid use. Someone told me I should have the heads checked for and warped areas. There is what looks like some carbon build up on the top of the piston bore hole. But that's opposite the side that actually was damaged from starting fluid.
The side with the carbon had coolant in the pistons when I pulled the head and it was there before I pulled it so I think it's safe to say that was the head gasket that needed to be replaced.
I was really looking to have this put back together today but now I'm wondering if I should have the heads checked out.
