Diamondwhips
So I have been a member here for about a year getting lots of great info. I have come to a problem that I can't pin down and would like some advice. So here's the deal I bought my truck in February and have had starting problems from the get go. First problem was air getting into the fuel system and bad glow plugs. Once I fixed those and about 3 months after I got in the truck one morning and got a series of knocks that went away. Nothing for a week or so then it's knocking again on a cold start but clears up.
So I'm thinking either bad injectors or bad injector pump or both. I get a hold of Mel and get a new pump, injectors and return line kit so all should be good
. Next morning 2 knocks and the truck is running rough for a few seconds than its fine. I'm thinking ***
and call Mel to see if he has any insight as to whats going on and he thinks it could be a bad valve guide. The reason he thinks this is because you can hear a huffing sound through the intake when the starter is turning the engine over.
So here's my questions, does anyone have a good way of testing to see what guide or guides are bad without pulling the heads?
Is there any other things I should be looking at to determine what might be wrong?
At this point I'm about to part this thing out but want to make sure.
The truck in question is a 1992 Ford F250 NA bone stock with the exception of a larger exhaust and a new transmission
