KingPin Dana 60 Front End
Worstenemy453
King George, Va
How can i identify one and what trucks did they come in. Im going to pick a part on Thursday and im hoping i can find one chilling in their lot.
Dieselcrawler
Professional wrench holder
Staff member
Quakertown Pa
on the knuckles there will be a cap bolted on from the top. has 4 bolts in it. located where a balljoint would be.
NMB2
Dunce
Ft. Lewis, WA
78/79 F350 and sno-fighter 250s. All 85.5 - 91 F350s. But dont get stuck on the Kingpin. A BJ 92-97 is fine. 96/97 being the best.
Good luck finding any of them at the pull and save.
Worstenemy453
King George, Va
IS a 96/97 BJ D60 better than a Kingpin D60. I want to a D60 swap and im not overally concerned with it being a Kingpin but if the King pin is the best then ill try for it first. I know i will leave that junkyard with a D60 if i want.
NMB2
Dunce
Ft. Lewis, WA
My opinion's are based on different applications, but in yours I would say the 96/97 would probably be the best. You aren't going to have any issue with strength no matter which axle you use. For your application the only advantage between any of them I see is the 96/97 having the better brakes.
jam0o0
houston, tx
if you like taking things apart to service them then get the king pin. other wise get the ball joint axle. the brakes are held on better on the ball joint axles.
the pre-80 axles have a different differential offset (side to side) than the 85 and later ones. don't get a pre-80 unless it's going in a jeep or a pre-80 truck.
jam0o0
houston, tx
maintenance is debatable IMO. my kingpin needs to be greased just as often as my old ball joint stuff.
as far as rebuilds i haven't seen anything one way or the other on which lasts longer.
for big tires and abusive wheeling i've heard that king pins are stronger. but unless you are running 40"+ tires on a 6K+ lb rig landing wheelies with the throttle pinned, it's not a big deal.
high steer is easier with kingpins too.
Worstenemy453
King George, Va
Im trying to increase my turning radius and get a straight axle. Ill proly only go 4" suspension with 35"s when i get around to doing a lift.
NMB2
Dunce
Ft. Lewis, WA
I've never touched my ball-joint's in the last 3yrs. Not even greased them. This is a 97 D60 under my rig.
