KentMoore
kool55
Chase City VA.
No , but I have been trying to find some info on the net. Not much of anything . I tried logging on to SPX Kent Moore website but can't.
Kool... Do you have any instructions for your meter. I have two sets of directions for my J33300 meter.
kool55
Chase City VA.
I don't have a meter yet . Looking to buy one when I saw a J 33300-A Model available . That one you can hook up a timing lite to. Don't know about the J33300. What do you think? Can't find an online manual either.
kool55
Chase City VA.
Update, pulled the trigger on it last nite. Seller found out you can use a timing lite on a non 'A' model. Will use it as soon as it gets here I am sure IP and injectors are next. [Hellow Mel.....]
Well... I was posting to say buy the new meter on ebay. Just hook it up and press the offset adjuster rocker switch. All the reading change to zero and you are set. Run the motor up to 2000 rpm on the meter and read what the timing is... No need for the timing lite either. Its that easy.
kool55
Chase City VA.
I just wanted to have the option of using the lite., maybe if the mag pickup can't pickup a signal?
