kool55
After picking up a J33300 on ebay I have decided something must be wrong with it. I have not been able to keep the timing display within 8 degrees and now the RPM reading is jumping between 300 to 2000 while keeping the throttle steady at appox. 2000. Today I tried the luminosity probe method with a more consistant degree reading but the RPM reading still inaccurate. So out of frustration I ordered a Ferret. I am thinking when it arrives and I get a solid reading I can condem the K-M. to repair,[if they still fix em]. I don't think # 1 inj. is giving a bad signal since I adjuster the IP and the smoke is gone as well as running much better,. I did put the pulse pickup on #3 with no improved reading.This is a PITA but I am determined to figure it out.For those of you that have used a J33300 were you readings steady?
