Baytonia
Got the 7.3 today
Once again thanks for the advice.... I picked up the 7.3 today, came out of a 89 F250 with 86K miles. Cost $700.00 complete motor minus alternator, they did a good job disconnecting everything. I want to place it on an engine stand, this thing is a beast, does anyone have any plans for building a engine stand? or who sells a good one? Hopefully the 6.9 will run ok. This is what has been done so far, after draining the pan all night, I placed 5 gal of diesel in it to soak, WD40 in GP holes, tonight marvel mystery oil in the GP holes, I will turn the crank a 1/4 turn in the AM. I tested the GP's with my small lawnmower batt. 3 of the GP's did not heat up. I am hoping that was the original problem which was cranking but no start. I also poured a quart of trans fluid in the intake to soak. This will be very interesting to see the outcome. 2 weeks ago I could have cared less about a diesel truck, now look at me. I feel like a kid 2 days before Christmas wanting to open the packages now. I want to give this engine every chance to run right the first start. One good thing is I have the 7.3 as a back up. I have attached the pic of it. I see what looks like the rear main is slightly leaking, so I want to re-gasket the entire motor, including the head gasket. But first I need an engine stand.
