UPDATE!!!!!! UPDATE!!!!!!
UPDATE..... I did what TOWCAT told me to do and it WORKED!!!!!! I am so happy, water shot out just like he said using the pry bar. I then hit the starter and it looked like niagra falls...... My truck beside it got soaking wet. The mosqutoes were eating me up so it covered the motor with a rug, closed the hood and left. This is a awesome site, I could have never done this alone....You guys are awesome, especially TOWCAT, I did it like he said. Now, my question is what next?? Should I spray some PB blast in the glow plug holes and let it soak??? should I test all the glow plugs while I have then out? Should I leave the old oil and filter in it and let it warm up before I change it? Can I put water in the radiator, I didn't see antifreeze in the neck? Can I put the fuel in the tank, been sitting 2 years with the caps on tight, should I rig a aux tank to fire it off? Some many questions,....... I am so happy I don't know what to do.... A Thankyou for everyone who cared enough to give me advice. Also should I try to do a compression test before I run it? I got a good feeling about this truck....I feel the motor will be fine. The old man told me it ran perfect. Oh one more thing....... The problem with the truck originally was it cranked but would not start. He said it took longer and longer for the wait light to come on, then finally I would not come on any more. I looked at the GP relay on the fender and the wire on the small post toward the engine is missing. I see a hot wire and a ground wire going from the battery on the driver side through the firewall, it looks like the hot wire has an inline fuse. I don't know how to troubleshoot that? I think someone rigged the glow plug system, so I can't begin to start it now anyway, until I troubleshoot it. HELP once again.....
