jsnap
Dunce
Ok fellas tell me what you think in my opinion and yeah i no about opinions but hear me out the main cause of glow plug failure or maintinance is they go on every time you turn the ignition even for a short time when you sure dont need them. Now i know you can manually wire them to work when you want them to but to me thats a 2nd rate solution. So i was thinking to take off the hot wire that gets hot with the ign on at the glow plug relay , and say ataching a jumper from the cold advance sol or the high idle sol to that post on the relay this way the plugs would only come in when cold . I know the temp senser pulls the solenoids out at about 115 so what do you think if the engine is warm enough not to need advance or high idle you think it would be warm enough to rattle off. AND NO WISE CRACKS ABOUT OPINIONS BEING LIKE A H----- EVERYBODY HAS ONE AND THEY ALL STINK. Thanks fellas Richie M
