Junior moose is in
S-west
Ct
Well most of the way. I got home today and there was my new moose junior ip and naturally I couldn't wait to put it in. So I got it all in and the last thing I need to hook up is the return line to the top of the ip. Only problem is I accidentally broke the 90 degree connector while taking the old pump out. Anybody know where I can get one? The auto parts store says they have never seen anything like it.
The Warden
MiB Impersonator
Fog Bless Pacifica (CA)
You should be able to get it at an IH dealer...that's almost definitely the only place you'll find it these days; I don't think even Ford carries it anymore...
S-west
Ct
Great. I have to buy 2 now because I convinced my buddy who's 6.9 is just sitting to let me borrow his and I broke that too. Is there a truck to getting them out?
Hardy41
Orange,Ma
If you can't get one from a IH dealer, I think I have one. I am in Ma. What part of CT are you from?
S-west
Ct
I live in stafford springs. Ill have to let you know if I can't get one from the international dealer
The Warden
MiB Impersonator
Not that I know of, other than to not use too much force. They are made of either brass or bronze (can't remember which), so you can't torque them too much without risking a break. IIRC the 7.3l ditched the elbow in favor of a hose nipple; you could go for that and eliminate the steel line going to the back of the engine (although you'll need another hose nipple on the other end also). Hitting the threads with penetrating oil before trying to loosen it might help...
ah1988ford
florida
lowes or hd might have it or something comprable its just a brass fitting.
S-west
Ct
I guess I'll have to make something. Just went to the international dealer and the guy looked at me like I was crazy when I said I had a ford with an international motor. And he couldn't look it up without an engine serioul number. Rather make something than try and explain myself to that guy.
S-west
Ct
Just checked brass fitting to see if I could put a few together to make something. But the return line side has some special thread on it and nothing maches up. All I know is its close to 3/8 npt but not close enough
S-west
Ct
It matched up? I was looking at the npt fittings and it looked like it would strip out the threads on the return line.
Not to worry. This is a simple low pressure gravity return sysytem. Just find any fitting that will thread into the top of the pump. Make sure that check valve is working in the injection pump top cover. Thats the fitting that has the o-ring under it. The part you broke is nothing special. Most any unjection pump repair shop will have something that will work. I'm thinking you have the steel line that runs from the top of the pump. If so you can cut it and use some 3/8 hose and clamps from the pump to the return line. Like said. It no pressure. Just a gravity return to the tanks..
S-west
Ct
Ok thanks. I wasn't sure if there was pressure there or not. I just want to get this thing running to see how my new pump is!
