Mikes91
I'm wondering if my fueling system is OK due to some weird behavior with the truck.
When I stab the go pedal, she'll go, but oftentimes when I left off while she's under heavy pedal she'll surge forward like she has more power back there somewhere just as I let off the pedal. I'm not talking just a little bit of power... the whole truck will surge...
Is this behavior normal?
The lift pump's job is to draw fuel from the tanks to the IP, yes? Maybe low lift pump?
For a turbo'd IDI, my truck seems low on power compared to what 1 or 2 other people here are getting... especially considering I have a rebuilt IP in it. Barring low compression, would a weak lift pump cause this? What other things should I check? I do get a puff of white smoke at the first start of the day, just a puff though so not glowplug system related. Not sure if that's related or not...
Mike
Mike
