Izzit possible to change the Brake Booster without removing the MC?
not hard whatsoever.
the lines have enough give where you can disconnect the master from the booster with the hardlines attached. swap out your booster and bolt it all back together
gnathv
Athens, Al
When I converted to hydroboost, I tied the MC to hood with rope so it would not fall and damage lines. Plenty of play to get vacuum booster out. Hope this helps.
