psy9zach
Did you guys snatch your pin out of your vacuum booster for the hydroboost?
Sent from my ASUS_A006 using Tapatalk
Hce I'm doing this the same way you did do in order it and which one
I do not know, my hydroboost came with the rod, I find it odd your did not since it is the same part number.Hce I'm doing this the same way you did do in order it and which one
Did not pay much attention other then there was a rod in it.Was there a spring or anything or just the rod that sits between the two?
