Is there a "Heavy Duty" 3G alternator?
Darrin Tosh
IDI Hound
Grand Rapids, Michigan
What I mean by Heavy Duty is something for a HD applicaton that has better longer lasting bearints,.
Here's why, I have been going through the bearings on my alt about every 4 months. It seems that the Cummins Belt Tensioner is tighter than a Ford one.
It just seized up again on me last night, I got it pulled off this morning, and sure enough, the bearings are bad. I can bring it up and get the bearings replaced again, but I want to FIX the problem, not just fix the alt.
Any suggestions?
argve
Resident Fruitcake
Gwynneville, Indiana
If you can't find a better alt, get the size of the bearing and see if your local industrial parts house like for example Motion Inc can get you a better bearing. trust me Motion won't have it in stock but can get it to you the next day.... they have never had what I needed in stock. They should be able to get you something. I would suspect that the rear sleeve bushing is what's going out because the front should be a full fledged bearing.
That's just the industrial maintenance experience talking.
Darrin Tosh
IDI Hound
Thanks Travis, I am bringing it up to my re builder again and ask him if there are better bearings out there that can be used.
A Dodge alt would be an option but the motor is setup for the Ford, I would have to get different brackets, and wiring as well I assume. That will be a last option.
I will probably just have it rebuilt again for now to have it drivable again and when I park it for the winter in the next month or so I will look into different options.
LCAM-01XA
my very own hell
Darrin, call the guy at RJM Injection Tech, he builds custom alternators and he's semi-local (Lansing) so he may be able to help ya out: 517-455-7352
Darrin, when these bearings have been going bad, are you just getting the bearings replaced, are you getting a whole alternator, and in either case who is the source? Have you tried a genuine Motorcraft alternator? - Mel
jperecko
Diesel Ape
Boonies of SoCal
I have done my fair bit of research mostly with the offroading community and bought a powermaster 200 amp 3g alternator. They have it in lower amperages as well if you do not need that much power and basically everybody who used and abused them did not have any complaints from them. It is all bolted up to the Cummins but as the engine needs some coolant and wiring still, no word on my personal experience with the thing.
Darrin Tosh
IDI Hound
Thanks for all of the input.
I gave called them a couple of times, no answer :dunno I'll try them again later,..
You could always put a Leece Neville alternator on it. That's what is on my truck.
I hear those are good, I'll check them out, Think they are expensive,. :dunno
It is geting rebuilt with new bearings. This time he said it just took out the front sleeve, not sure what the source is. He did put the better bearings in it last time, but he his going to see what else is out there. He is a rebuilder that I have been using for 10 years, he knows his stuff, charges me $30.00 to rebuild a G3. Considering a New Ford one as well, But as you will read, I think I have the problem taken care of,...
It looks like I got it covered,.. I eliminated the belt tensioner. The way this is set up, The alternator is adjustable, so I removed the tensioner, tightened the belt with the alternator and bolted it down. I didn't even need a shorter belt, it fit correctly. ;Sweet
So well run it like that and keep an eye on it but for now I'm gonna call it good!:D
Compu Doc
Middletown NJ
Hope it all works out. The belt tensioner might have been putting to much stress on the alternator bearings.
As for the Leece Neville they are expensive. About $250 for a rebuilt one but if you need to go that route make sure you get one with a lifetime warranty. I had a few that went bad but they were replaced at no cost to me. The one in their now has been for about 4-5 years maybe longer.
Mat J
Way down south
Jupiter, FL
alex that looks like a bad ass little rig i like its home made what all is it made from
Alex S
Jeoff
New West BC
No just an 11HP B&S turning a 3G that i bypassed the regulator. So i run 12V threw a dimmer then to the filed circuit on the alt, that controls the alt output and i just have a lil tig torch connected to it. Its a scratch start though. I have made some improvmenst and added a spark stabilizer and also a wire feeder for MIG welding as well. Its an ongoing side project
Bo17
