GREASE FIRE
my fuel filter has less than 1000 miles on it and the other day just as i was getting on the highway the "fuel filter" light came on the dash. Truck was running fine and the light would sometimes go off and then come back on.
Then, after the truck was warmed up, i hit the switch on the dash the draws fuel from the wvo tank in the bed, which has a heated fuel pick up and heat exchanger a few inches from the fuel filter, and the light immediately went off.
i switched back and forth a few times and it would eventually come back on with diesel but when i switched back to wvo it would go off right away.
there must be a pressure sensor in there that "works" because it is sensitive enough to register changes in fuel pressure - but is it really accurate enough to tell me when the fuel filter will actually clog and stall the engine?
i only drove about 20 miles on wvo that day but the light did not come on at all, and even after switching back to diesel before shut down it did not come on.
i keep extra filters on board of course but i am just wondering whether i should really take this seriously enough to change filters now. BTW i have PLENTY of diesel anti-gel in the tank so i am sure that is not the problem (probably at least 3X as much as is needed).
any comments appreciated!
thanks,
Paul
thanks,
Paul
but the filter that plugs on me is the 2micron i have on my framerail before the e-pump.
