I found for my unit like that I had to drop down to 2 business cards to get a stable signal. If your pump is off a tooth it’s going to cause you grief timing. If I recall from my timing, I was about 4 degrees advanced at idle compared to 2000 rpm. Just FYI. At one tooth out, you will probably have a difficult time getting timing set to the 8-9 ish degrees btdc. I don’t know who told you to Advance the pump but even on a cam swap that requires it, I don’t think you Advance the pump. You just advance the cam gear right guys?
