IP Pump
Worstenemy453
King George, Va
Ive read about turning the IP up. Im snatching Autometer EGT and Trans gauges on Ebay right now. Im keeping my truck N/A and will buy some BB injectors shortly. I wouldnt mind a little smoke cuz i will be doing stacks soon but i dont want too much. How many turns should i turn it and which one am i turning ?
Probably nobody will tell you how to do this before you install a pyro. If you know how to "turn up the fuel" first without a pyro you very easily will melt a piston. You really need to know how hot the exhaust is before you attemp turning up the fuel. Most na motors run hotter than turbo motors because a turbo pushes in much more air to cool the cylinders and exhaust. Its not a hard thing to do and many can and will explain how its done properly and safely....:D About all you need to do is turn the allen wrench one flat. Thats all it takes usually. I think Banks turns the pumps up 1 1/2 flat and go from there. They usually send you on your merry way with a pyro up around 950 degrees and 1050 is there recommended top temp....
