boxathey
I just installed a freshly rebuilt IP pump I purchased at a local diesel shop. (http://www.wimerfuelinjection.com/). It has a factory turbo, the IP pump was calibrated for a factory turbo also. after start up I let it warm up. Then using the timing meter I rented off of icanfixall i timed it to 9.1 btdc @ 2000 rpm using the #4 cylinder I also had the air cleaner housing removed, and temporarily installed a dryer vent to prevent sucking any debris during the timing process. took it for a test drive last night, the truck ran great, good power, turbo spooled up nicely. I drove it all over town thru out the day about 50 miles or so. I noticed black smoke out the exhaust. I get some about 1/4 to 1/2 throttle when shifting into the next gear. mostly 2nd to 3rd. and 3rd to 4th. its not a crazy amount of black smoke but it is definately noticeable and consistant when on the throttle. Is this normal for these trucks ? I ask this because for the four or five years Ive owned the truck I have never seen black smoke except on rare occasions. I decided to throw the timing meter on it again after the driving except instead of using the #4 cylinder I used the #1 cylinder. (#4 cylinder is blocked from the air cleaner housing) I also left the air cleaner assembly completely attached. the timing meter read 5.5 @2000 rpm. is it possible getting a different reading cause i used cylinder #1 this time ? Or because when i timed it the first time i had the air cleaner off ? Or is there a break in on the pump and i need to re time it after a couple hundred miles ? Tomorrow im going to check the timing again using the #4 cylinder like i did when i first installed the pump and see what the readings are. Thanks for all the help.. By using the tech article i found on this site. It made installing this ip pump a breeze. also a special thanks to icanfixall for his timing rental program its been a huge help.
