IP issues
chillman88
Central NY
I definitely think it's a supply issue. It started fine, just wouldn't stay running. Like a carburetor emptying the float bowls and then dying.
sjwelds
Central KS
Guys, I thought the Schrader valve is after the filter. Could someone clear this up for me?
Thanks
chillman88
Central NY
This my friends is Mr. A. Hole.
Not mine, but it's the same part.
After installing the new pump to no avail, I tried switching tanks in case I was somehow pulling air. I know my front tank is just under half, but the gauge wasn't changing. Blown fuse for the tank switch. Swapped it out and it blew again.
Sure enough, a nice bath in some diesel and a few feet of rubber hose and I should be able to get to work in 4 hours.
If anything changes I'll let y'all know. Hopefully my hack patch job holds up until Thursday when I can fix it right-ish and use 5/16" return hose instead of the 1/4" I had.
lewisstevey7
