I'm having some trouble visioning how the senders are wired. Does the wiring go from the tank, to the fsv, to the tank switch then to the gauge? Does it require something from the fsv to function? I would think the senders just run from the tanks, to the tank switch then to the gauge. In that case, wouldn't the senders still work without having to rewire them to another switch? It would be really convenient if I could still use the factory tank switch to switch between senders.
Edit: I re-read my old thread and it pretty much answered my question. ... I've been running on almost zero sleep so my brain is pretty foggy and slow
I had to run back to motion flow, so far I'm into this swap about $140.
As soon as I get home I'm going to drop the rear tank. Hopefully I'll have this finished today, before the sun goes down and it gets COLD.
