alwaysdiesel
The new guy
Hello,
I've been reading threads on Obs for a while now and decided to get an
account. Recently I was having hard hot start issues and good cold starts. After doing some research and tinkering around, I came to the conclusion that my injector pump was toast. After reading lots about the Moose pumps, I figured it was a good way to go and ordered a moose junior. Last week I removed the old IP and injectors ( replacing them with new BB codes) the removal of the pump was fairly straight foward. I do have a few questions though. When I receive the Moose pump, what precautions do I have to take to properly install it. I've read several installations talking about making sure its at top dead center. How will i be sure the pump is in properly? Also, on the pump, where does the number 1 injector go as in where the injector line hooks up to the injector pump. I know the firing order but unsure where #1 goes. Is timing something I should get mechanic to do? Obviously I'm quite new to the scene but very interested, these engines are so reliable and just nice to drive. Thanks to all who help!
P.s Is anyone running Moose pumps with the stock lift pump or is an electric pump recommended?
Max
Max
