junk
Well I got my injectors pulled from the 93 tonight. 7 of the injectors don't look too bad. One was loose. It turned while I was trying to remove the fuel line. And it's completely covered with soot up to the top threads. They are all G code injectors. Dates on them are late 93 and early 94. A couple of them were discolored and one had a little bit of rusty stuff on it.
So how should I clean the bore from the sooty injector hole? I'm thinking a seat reamer and a shot gun cleaning brush? How do the rest look? This is the first set of injectors I've ever had out.
Also how the heck does a guy get the pump and lines removed from an engine with a 093 turbo system? I ended up loosening up 4 of the fuel injector lines and fought it for a while before I finally got it snuck out. Without the turbo it looks like a piece of cake.
Jet Engine Fuel Systems Repair Station owner. Still hold the Repairman Certificate {fwiw]. Anyway, my point is, I've repaired and returned to service a few thousand sets of fuel nozzles.
