Just went out and fiddled with it some more. Started backing the line nut off and noticed it was twisting the line up! The injector was so loose again (already) that I had to hold it with the cresent wrench to keep from tearing the line up. Re-re-retightened #4 injector. Replaced the filter with a new Hastings filled with ATF and started it up. Ran for 3-5 minutes with no change in engine sound
![dunno :dunno :dunno](/styles/default/xenforo/smilies/shrug.gif)
Guess I hit the return cap, noticed some bubbles under it, but more from the injector bore around the threads. After I shut it off, there was so much diesely blowby from the injector bore that the lines and clamp next to it were wet (line might be damaged now, even though it wasn't before). It had a noticeable miss, but it was intermittent. Going to let it the ATF sit overnight and see if anything acts different tomorrow.
Could the #4 injector have stuck CLOSED instead of open, causing it to de-seat the injector? Didn't see the hex head on it rotate while idling, so maybe worse under the load of driving the truck? When I replace the injectors and clean the bores, could I get away with PB Blaster and a pick or screwdriver to clean out the carbon build up? Would there be any adverse effects from letting the carbon fall into the precups/running the engine when I clean it?
This now has me a month behind schedule.
