Alright, new development...
First off, I've referenced my injector numbers wrong previously, either in this thread or someone else's, but I found/saved a diagram to help me (I think). Injectors on drivers side are even numbers and passenger side are odd, correct?
Anyway, replaced the stuck open #6 injector with the loaner that Russ sent me. It came out in pieces and was caked with carbon. Makes me fearful that replacing all the injectors when the new ones show up is going to be a longer process. One of the 3 little pins inside the injector was gone. I dropped another in the hole and instead of stopping like the rest, it dropped all the way in (came back out). Needless to say, I had to roll the engine over with a block of wood over the injector bore to capture the pieces (only 2 small pins in there before I did this) and grind the threads off the injector and thread it back into the other have. Thankfully it caught and I used a screwdriver to put enough pressure on it to come out while I spun the injector. Copper washer was a PITA. Don't have a pick long enough with a short enough tip on it, but I put a little screwdriver on the grinder to make a tooth and spent about 5-10 minutes picking at it before it popped loose.
Torqued the new injector to 33 ft lbs after using petroleum kelly to hold the new copper washer on. No anti-seize, so I used jelly on the threads for now (anti-seize on my list) and coated the o-rings and return cap. So much so that there was no click when pressing it on, but felt it land home, doesn't seem to leak. Threaded the line nut on and started the engine. Noticeable miss at start up, same as before replacement, but smoothed out. Guessing that was the fuel bleeding through the injector. Noticed that the #4 injector had smoke coming off it. It could have been left over fuel from the old return cap that was spraying. But top of the threads that I could see above the head were wet on the new injector after startup (petroleum jelly melting?). Noticed before I started working on the truck today that the wire loom for the GP harness was a little melted where it contacted the #4 injector. After shutting the engine off, #2, 4 and 6 injectors where hot, #8 was warm, but all passenger side injectors were cool to the touch. Does it sound like all the drivers side injectors are starting to stick? Why would the new one be hot to the touch (unless it was warm from having air in the line)?
I have a pic and video uploading now that I will post once they show up in my photobucket.
