So here's an update:
I got a bore brush, some carbon cutting solvent, made a carbon reamer out of an old injector, picked up some new viton O-rings and new copper washers and got to work. The cylinder that was giving me problems had an old injector washer buried in a ridiculous amount of carbon! So that would be THREE washers i got out of that bore after taking the old injectors out. No idea how I missed the last one. Almost every bore had more than one washer, so PO or their mechanic sucked. Then I got some serious chunks of carbon out of the bore when brushing it with a light amount of solvent. Didn't want any running into the precup/cylinder. A vacuum aided in getting it all out. The reamer worked perfectly. Got everything off the seat with ease. Then a shop towel with some solvent got the rest of it off. Nice clean seats now and no cuts in them so I don't need to use a cutting ream. Well, so far. I'm spending about 20-30 min per bore making them like new. Got a few more to do. Thank you guys so much for the info, especially the old injector reamer!
