Ingition Lube...
freebird01
Post Turtle!
Fort Wayne, IN
Ok i know this sounds like a dumb question....but what have you guys found to be the best product and method for re-lubing the ignition switch for operation in cold weather.....
mine is a mother!@#!#$ to turn when its super cold outside....
can i squirt something in where the key goes and be ok? or do i got to pull the column apart?
and im about ready to just buy myset of cables from the custom battery cable website...im gettin pretty sick of messing with them every few days so my truck will start...if it wouldnt be for the cables this thing would start great in cold weather...
h2odrx
Anti-O
Coastal Neckville, NC
most likely it is the switch on the column causing the problem. cables are a pain, a battery man told me once years ago, "every time you check your oil drop a drop or two on the battery post and no more problems." I've been doing this for years now and it works.
Vincent
