IDI timing advance arm
timothyr1014
chandler. az
just installed a new ip in one of the trucks.....set it to the marks and it is acting way to advanced...actuate the arm and it starts sounding normal.
I am totally brain dead right now (and have spent the last month working on complex japanere FWD fuel injected crap)...what am i missing?
dyoung14
Is getting worn out
spencer,tn
As you give more throttle that arm retards the timing, try retarding your timing some and see what it sounds like then
Timing without a meter is just not a good way to time these motors. The marks are just a starting point at best. Retard it some and test run it till you find what you like but... Having it timed with a meter is the best way of doing this... Finding someone that can do it and prove they did it is the hard part....
timothyr1014
chandler. az
what got me looking at the arm was that I couldnt retard it any further and the rattle and smoke would put a cummins to shame...at first I was thinking I was a full tooth off, but then for ***** and giggles I stuffed a piece of vacuum line behind the arm (where the throtle piece would hit it) and drove around the block...ran perfect.
dyoung14
Is getting worn out
spencer,tn
Then the timing is absolutely too advanced
timothyr1014
chandler. az
could I be a full tooth off, and if so how do I fix it?
with the arm sitting in its normal position it without a doubt is acting too advanced regardless of how far a retard it (towards the drivers side)
dyoung14
Is getting worn out
spencer,tn
Did you pull the gear cover? and it sounds like how my pump use to when i was messing with screws inside the pump that i shouldnt have, after i turned them back to were they was it fixed it, maybe the rebuilder sucks:dunno
timothyr1014
chandler. az
pump came from MWFI...dad gave me a gift certificate, and I dont have a ton of faith in them....to install I pulled the 3 bolts for timing, and the ones inside the oil fill neck...didnt pull the cover off.
JU57US
