IDI OIL PRESSURE TO START
PROFG
SE CT
Noticed while priming that spins faster after couple seconds cranking (oil pressure starts up). Would wear be improved by use of accumulator/lube prime pump or could I just keep shut off solenoid off until I see oil pressure (starts first compression anyway so still using single battery).
PROFG
SE CT
Anyone? That's crazy or don't worry @ it, or ????
PROFG
SE CT
riphip
Memphis, TN.
You are getting low pressure/High volume on the IDI engine. Some have added accumulator (way in the past) but you should be fine.
FordGuy100
Silverton, OR
Is it needed? No, there seems to be a pretty solid track record of IDI longevity when taken care of. Would it help? Absolutely.
I've seen one or two 6.2/6.5 guys do it, none on a 6.9/7.3 yet.
If going off the factory "gauge," get a real gauge and compare.
PROFG
SE CT
I have a real gauge and video today it sat on zero until she started (cranking did not speed up like day before). Overnight @ 45F and yesterday @ 60F so maybe should change oil to 10-30 and try again. Don't remember whether gauge pressure or electric but will find out, maybe capillary tube slows response.
chillman88
Central NY
I ran Rotella 10w30 for the last two winters over here in NY, just because I got 5gal on sale at wallyworld. Didn't seem to make any difference really. IIRC the spec is SAE30 in winter so you should be safe.
I agree with Jasper though, I'd run the 5w40 as long as you don't find that your engine drinks it like water. I thought about it but didn't feel like spending the extra money cuz I'm cheap lol.
RetiringColt
Washougal WA.
I haven't installed one. But an accumulator would be nice for a turbo engine. Not for the start-up, but the engine shut-down. Save on the turbo. I try to idle the engine a bit before shut-down. Just can't justify the extra expense.
PROFG
SE CT
Same here, cheapest 3 qt Accusump @ $220 on fleabay so thought to try just holding FSO closed until cranking speeds up (but no speed up). Wanted to change oil/filter anyway so will try 5-30 and try to drain oil cooler / flush pan also. Accumulator better since would work for both shut down and start up.
PROFG
SE CT
Thanks but found them and looking for something more in line of surplus / overstock (cheaper), but may have to go this way for pressure. More like this I might try for $90.
Brand: SZMWKJ
Model: MOI-0105
Rated Voltage: DC 12V
Adaptable Voltage: DC 11-18V
No Load Current: 4A
Working Current: 12A (3MPa)
Flow: 1L/min
Inlet Diameter: 6mm
Outlet Diameter: 6mm
Rated Power: 300W
Rated Pressure: 5MPa
Working Pressure: 0-10MPa
Max Pressure: >18MPa
No Load Speed: 3000 r/min(12V)
Work Temperature: -10℃~80℃
Apply for: Oi
Net Weight: 730g
Direction of Rotation: CCW (Look from the Motor Direction)
Warranty: Two Years
needed (60-90psi).
Kizer
Denton, Texas
Brand: SZMWKJ
Model: MOI-0105
No Load Current: 4A
Flow: 1L/min
Inlet Diameter: 6mm
Rated Power: 300W
Apply for: Oi
Net Weight: 730g
Warranty: Two Years
needed (60-90psi).
I just thought they were cool. With accumulator (in my head) you would want 1 for pre lube and a separate 1 for shut down ... you could just put this pump on a timer + momentary switch and get both ... + no 3qt accumulator to find space for.
PROFG
SE CT
Your right, was planning on one pump or accumulator for start/stop (+ have another job possible for pump), secret until it works:D
BeastMaster
Orange, California
From above....
Check this out:
upload_2019-10-13_8-27-32-png.125122
I have some of these. Used them as transfer pumps. Nice little gear pump.
Don't like to run em continuous...they run a bit hot for my liking. They use 3/8 inch fittings. The home Depot fittings fit.
I think $300 is a bit pricey though.
Try here...
https://m.aliexpress.com/item/32740558700.html
$100 ballpark. By the time you throw shipping in.
Betcha this is where they get 'em.
There are several vendors selling the same pump from what I see. Different pricing for pump and shipping.
I have done a lot of business through AliExpress. Most of the industrial stuff has been on the up and up, but most of the cheap fashion stuff meant for retail resell has been a disappointment to me.
dogdanblue
