IDI Cooling System Capacity?
robw
seattle, wa
To resurrect an old thread, my radiator barely takes 2 gallons before it tops off.
How does one successfully flush a radiator with distilled water, and then get 4 gallons of antifreeze inside of it?
Golden Helmet
Monterey County, California
The block is holding a lot of the coolant. There are some block plugs you can remove that'll drain most of it out, one by the starter and one by the oil cooler according to this quick and lazy Google search. I can't give advice on flushing because I don't do it right myself, I just drain the radiator and refill.
robw
seattle, wa
^ perfect.
I ran about 10 gallons of distilled water into the rig to flush the old coolant (which was fresh anyway), drained the drivers side and radiator, put in 4 gallons of Motorcraft gold and topped the rest with distilled water.
CHEERS!
I think you may have a little bit too much antifreeze in there if you put in four gallons. You may want to check your freeze point. I think too much will actually raise the freeze point.
Scooch
Temiskaming Shores, ON, Canada
Going from a 50/50 mix of coolant/water to say a 60/40 of coolant/water will lower the freezing point not raise it.
Also, the idi system is listed as around 7-8 gallons so 4gal of coolant assuming its concentrated not a premix is more then fine? Could even go up to 5gal and be okay in all reality.
That's assuming all the old stuff has been removed or else who knows what the concentration will be
When I used to work at a shop and was doing R&R work on these constantly, I'd put 6 gallons back in the radiator. That's after the had been replaced. The only things holding coolant were the heater core and the overflow tank. I really can't see the heater core as having much capacity. That's why I made the comment.
DrCharles
West Plains, MO
I believe the lowest freezing point is at 2:1 (67% antifreeze, 33% water), something far below what almost anyone needs (like -74F). The 50/50 recommendation is basically to save money since -34F is enough in most of the US. Likewise for the boiling points.
But pure ethylene glycol coolant will freeze at a surprisingly high temperature, somewhere around 0F if I remember right!
robw
seattle, wa
I flushed the system with distilled water prior to adding 4 gallons, there was only a trace of previous coolant.
You wouldn't know I flushed it, when I pull the cap you can see little bits of junk the water pump has to push around. =/
Since the motorcraft gold has SCAs already, I wanted to play it safe with my turbo 7.3 and insure I had enough additives to prevent cavitation.
I love the plethora of information found here, thanks everyone for all your input. :D
renjaminfrankln
Raleigh NC
Yeah I thought about calling the ford dealer but I'm afaid of the price. And trying to find anything cat around here is near impossible. But I'll look into that also. The Zerex coolant says its good for navistar diesels.....
Buy the ford stuff on AMAZON about 10 bucks a bottle
austin92
Brazil. IN
What I did was drive with a system cleaner for a few days then drain the radiator, fill with distilled water, drive, drain, fill with distilled water, repeat until I had nothing but pure water draining out. Took about 5 cycles/15ish gallons. After I drained the last time, I filled with super tech (Walmart) green strait coolant. Took about 3.5 gallons. Drove, drained until I could add about a gallon of straight coolant. I was aiming for 60/40 mix, got about -40 freeze point. I added motorcraft sca to coolant and a coolant filter a few months later with need release media.
DrCharles
West Plains, MO
I should also mention that water transfers heat much better than ethylene glycol. Another reason that the 50/50 mix is most commonly used. If you're towing heavy in a hot climate I'd stick to that, but in really cold winter -34F may not be low enough. I've seen that in northern Maine winters...
Oledirtypearl86
Whitehall MT
I run a 50/50mix here in Montana and we hey temps of -40f for a few nights a winter and wind chill of -50f often I think starting everything once a day and letting it idle a few min helps a lot I had a time in North Eastern Montana it was -33 below at 3pm with a wind chill of -50 my truck idled for 2 days straight because I needed to use it for work
Dirtleg
Cloverdale VA
I've been getting the SCA additive, Motorcraft VC8, locally at both Advance and O'reilly. Less then $7 bottle.
