IDI Cooling System Capacity?
mankypro
Learning Slowly...
Boulder County, Colorado
Adding a coolant filter, figgered it was time to flush in any case and add a new bottle of SCA, since I have some on the shelf. Going to switch to a SCA coolant filter in the spring to forget about SCA's...
And yes I verified, 8 gallons give 'er take.
fields_mj
Brazil, Indiana
You had better get a second bottle of SCA. Flushed mine out this summer and it took 2 bottles just to register on the test strip. Half of a third bottle brought me up just past the service level.
mankypro
Learning Slowly...
I do have 2 bottles, that and the filter with the SCA's should do me...
Just redid the fuel system, going to do the GP's and the coolant to get
ir ready for the chilly *******...
hesutton
The Anti-Anderson
Bowling Green, KY
How many units are in the filter? I'm running an 8 unit Fleetguard. It keeps the SCA's at the upper side of the "safe" range.
Heath
85ford
Cameron Park/ CA
Yeah I thought about calling the ford dealer but I'm afaid of the price. And trying to find anything cat around here is near impossible. But I'll look into that also. The Zerex coolant says its good for navistar diesels.....
Maverick1701
Memphis, TX
Try a truck stop, they usually have ELC coolants - it's usually red/pink all the biggies make them.
Try any of your local truck stops - let your fingers do the walking:
http://www.google.com/search?hl=en&...+stop,+cameron+park,+california&aq=f&oq=&aqi=
or try diesel service places:
http://www.google.com/search?hl=en&...rvice,+cameron+park,+california&aq=f&oq=&aqi=
zombie thread time
so just to clarify...if its an ELC coolant then we are good to go and don't need diesel coolant additives. Is this correct?
Ramtough01
