Identifying 10.25, DRW axle or Spacers
dglambert
Rockport MA
Hey all just picked up this 10.25 axle, are these spacers or is this a dually axle? I will include photos of the doaner truck, door tag, and axle tag too. I believe the axle tag is V132C.
Thanks Again,
Devin
cpdenton
Truck needs paint.
Conway AR
That looks like a srw axle with spacers to me. Also, with the donor truck being a 4 wheel drive, it should be a conversion.
cpdenton
Truck needs paint.
Conway AR
Here is a vin decode. Says its a 250. So...conversion
VIN: 1FTHX26M4MKA57946
World Manufacturer Identifier - 1st, 2nd, 3rd Positions
VIN Code: 1FT
Assembly Country: United States
Make: Ford
Body Style: Pickup
Restraint System Type (Passenger Cars) or Brake Type and GVWR Class (Trucks and Vans) - 4th Position
VIN Code: H
Brake System: Standard
Restraint: Active (Manual) Belts
GVWR Range: 6,001 - 10,000 Pounds
Line,Series Body Type - 5th, 6th, 7th Positions
VIN Code: X26
Vehicle Line: F-250
Vehicle Type: Truck
Engine Type - 8th Position
VIN Code: M
Engine: 7.3 L
Cylinders: 8
Fuel: Diesel
Engine Manufacturer: INTERNATIONAL
Model Year - 10th Position
VIN Code: M
Model Year: 1991
Assembly Plant - 11th Position
VIN Code: K
Assembly Plant: KANSAS CITY, KANSAS
Production Sequence Number - 12th - 17th
VIN Code: A57946
Prod Sequence Number A57946
Additional Information
Wheel Axles Wheelbase: 310.0
cpdenton
Truck needs paint.
Conway AR
Well, I'm not sure. Mine is a true drw, so I don't know about that spacer. Someone will be along shortly that know for sure.
Now, Welcome to the site! I am sure you will find it very pleasant here. Kudos on posting pics on your first post. Took me a while to figure that out!
dglambert
Rockport MA
Yeah I am a regular on Ford-trucks but I was referred here for this question but I like the idea of a forum just for diesels
fordf350man
Rockwood MI
some spacers will use the factory studs to mount the spacer to the axle, but that one looks like it just slides on, i dont see any fastners holding the spacer on the studs but i cant really see it that well in the pic but once you get that spacer off the drum will be the same way, slides right off, unless there rusted, if that spacer does slide on a air chisel might be your best friend there
jaluhn83
Upper Marlboro, MD
Looks like custom studs and a slide on space. My bet is it's pretty nicely rusted onto the studs though. Big hammer......
crispy74
