biggin92
Yeeeee Haaawwww
We got it pulled out about 20 mins ago, he should be posting pics in a few.
Nope, not the adapter towcat, it's the bellhousing up and over the top from what I can feel. Will have it out completely in a few...waiting on another set of hands since I'm not comfortable snatching it out with a regular old floorjack.
The short response to this is yes, cast iron can actually be welded. But there are few welders suited to do so and they mostly work on railroad diesel heads. Why do I know this? Because my business is 95% cast iron, and I used to get it welded from time to time. It is expensive, time consuming and you need to not only remachine the part, you have to deal with probable warpage. The parts are heated to cherry red (about 2000 degrees F) in order to lay a bead, and there is still a high incidence of holes and hard spots.
Way easier just to get another part.
Using nickle rod is not welding iron, it is brazing.
what process are they using? MIG or TIG?Welp, I found bolt number 6 today while I was pressure washing this greasy ******* at school. And it only took 2 of the 3 passes I did with Purple Power and the wand to find it! Anyways, I spent a good hour just pressure washing and another 45 minutes sandblasting the broken off piece getting it prepped for welding....They took it in and were doing their prep when I left school so hopefully it'll be done tomorrow or so.....
