hypermax info
dyoung14
Is getting worn out
spencer,tn
What size is the up pipes and down pipe on a hypermax turbo and what is the size of the down pipe were it connects to the turbo?
Exekiel69
I'm not sure but I think the up pipes where 2" and the down pipe should be 2.25" or 2.5" .
punkmechanic
diesel tech
North East Portland Or
^^^ that sounds right to me. I never measured mine but from what I remember that is correct. as far as where it mounts onto the turbo it necks down from 3+ to the 2.5". Also hypermax sells an intercooler kit for this and larger exhaust.
punk
dakotajeep
Patrolling
TN/ND
I thought that guys on here were running downpipes that were 3" all the way? Maybe I have it wrong. If I remember mine (Banks) necked down to like 2.75" or so......I would like a 3" all the way, if there is such a beast.
Thad
punkmechanic
diesel tech
except for the mashed part on the ats that goes between the engine and cab;Sweet. As I said hypermax makes a 3" pipe that fits on the turbo, the problem is the clearance for it from there. I know a few have done body lifts and fit them in but I havent seen one in person yet.
Mine seems to do fine with the stock downpipe. I have 10psi at 2800 rpm when pulling an incline and the boost will hold. I do have 5" exhaust from the downpipe back to a 90* bend through the bed into a "y" and dual 5" stacks. the restrictive part is definetly the stock hypermax down pipe, maybe an upgrade in the future....
punk
FordGuy100
Silverton, OR
punk
No, the upgrade for the ATS kis, and the aftermarket ATS kits are 3" downpipe all the way.
I didnt think banks and hypermax had that small of downpipe.
82F100SWB
Sioux Lookout, Ontario,CA
I know my non gated Banks kit was a full 3" system, turbo to tailpipe... The Muffler and tailpipe are still on the truck that my turbo kit had came off of... LOL
The Hypermax "pulse" turbo is tuned to use those small pipes. Remember that increasing the diameter of the pipe will reduce the exhaust gas velocity. Small is not necesarily bad when designing a turbo with several feet of feed pipe.
Bo17
