Years ago I bought a hydroboost set up for my Jeep and never got around to using it. I am currently trying to put it in my truck. I could not tell you anymore what vehicle it came from. I thought I was doing well since my master cylinder fit right on and the bolt holes lined up on the cab.
The trouble comes in with the push rod. It appears to be way to long. It pushes my brake pedal up about 6 " more than the clutch pedal. If I space the hydro boost out about 2.5 inches it seems to be about right.
Do I need to make a custom spacer for my fire wall? Can I swap out the push rod. I do not immediately see how it even comes off.
Any help would be appreciated. Thanks
Unit in question.
Unit in question.
