I contacted Snap On and asked if they recognized any of the parts from that kit.
They said the larger wrench was part number SP60. I did a google search, and found the SP60 in cached images, but when you go to the link, it's busted.
Here is the cached image: (
http://public.snapon.com/R_RRD/Objects_lg/images/SP60.jpg)
I wasn't able to find an SP60 for sale, and the Snap On guy said they discontinued it years ago.
As for the other wrench, he said, "The closest available is actually made by OTC under part number OTC7461." I looked up OTC7461, and it is out of stock but $500 on Amazon:
https://www.amazon.com/OTC-7461-Fuel-Injector-Rotating/dp/B00063X0S0
On amazon, it says:
- Maximum fuel economy requires precise injector timing
- The tool securely grips the front of the fuel injection pump so you can rotate it while fine-tuning the system
- Works on Stanadyne rotary fuel pumps found on International's 6.9 and 7.3 liter engines
- Similar to Ford No. 303-228 T83T-9000-C
So that's the mystery Ford part number.
I searched for that part number and found
one for sale on Ebay for $200. Also I found it for
$500 on another site. And
for $160. Wow, here's
one with a $200 discount down to only $490. I'm still not confident that would work on a van, because the handle is just way too long. I'm 99% sure it would clash with my rear heater core lines mounted to the underside of the van engine bay.
The Diesel Stop website has a write up about
these luxury IDI tools here.
These are really specialty items and I'm contemplating making my own with a piece of plate steel and a grinder. I'm not dropping $200-500 on a piece of metal that turns an IP a few degrees.
