Waystro
No Class
How to replace front rotors calipers and rotors on my 86 f250 2wd
Any body have a guide?
FIRST I suggest do one side at a time...other side complete for reference to viewhint hint...
Jack up ONE side
Remove tyre
tap out slide pins with a punch, <<<<NEW slide pins are available and often recommended BTW
Pry wiggle and remove caliper, suspend it on a wire around spring or something to hold tension off rubber line
remove pads
clean the V notches where slide pins where located, on the axle and ON the caliper...good stiff wire brush
REMOVE dust cap from spindle,
remove cotter pin
UNDO, castle nut, HINT just turn it to flush with outter end of spindle
Grasp rotor on two sides like 3 and 9 oclock give a tug not too hard, pops outter bearing out..slide back in place
remove castle nut / washer / bearing
now carefully remove rotor,
Now you can thoroughly clean spindle and inspect for wear.
That is removal procedure, installation is reverse, add some brake lube on the V notches of the calipers and mount to allow calper so slide freely...
Bearing replacement is a standard procedure, repack etc...since you did not ask about bearings I'm not thinking you need to replace them
Also a NEW rotor seal is always a good idea when doing a brake job like this.
OK the other TYPE of pins, there will be a shouldered bolt retaining that setup in place IIRCThanks I'm going to replace the calipers and brake pad bearings rotors and drivers side break lines. I've never done any of this so throw out suggestions. Also my calipers didn't have 2 slider pins just 1 and it looked nothing like the one that came with my new calipers. The stuff I pulled off was a flat metal tray looking thing and the pin was curved down on the edges
That's the early style...I think they switched to the rubber piece in '87. I actually prefer the early style; they're not wear items like the later style is, and I"m not sure why Ford made the change.Also my calipers didn't have 2 slider pins just 1 and it looked nothing like the one that came with my new calipers. The stuff I pulled off was a flat metal tray looking thing and the pin was curved down on the edges
