pelky350
I tried to put a bungy on the gate and pull towards the front of truck, not very tight don't want to hurt anythjng but I feel like I should be making more boost and I think back pressure is making waste gate leak only seeing 10psi currently. Waste gate Is not connected to boost right now custom set up so nowhere to hook it up yet. Will simply tightening it properly help it not leak?. I have a 90cc pump with stage1's and factory turbo with banks compressor housing, 60-1 wheel mod and banks 2 3/4 exhaust and 4 exhaust after. 3 inch intake tubing and specter filter currently a little now dirty but searching for large paper filter instead. And installed intercooler recently but I was only seeing 12 psi before. With my 088 ats I could hit 19-20 psi I feel like I should be seeing at least 15? That's all I want/need. Just replaced fuel filter today. Not tons of black smoke either unless heavy acceleration from low rpms which should be expected. No obvious boost leaks. Intake hat seems to seep some but I don't think it's leaking with all new gaskets
