how to determine if my 01 has a GEM
without tearing the truck apart,
is there a way to determine if my truck has the GEM or the VSM?
maybe a site on the net where i can enter my VIN?
thanks!
If the fuse box is taller than wide, it has a GEM. If it is wider than tall, is has a VSM.
Found on the net, so take it for what it's worth. Lol
if it was the GEM, would it throw a code?
still having this issue, and it seems to be getting worse.
cant afford to replace it right now with the womans b-day and a the guest house project im working on.
hopefully next week.
What codes are you getting? I can send you my AE and a disk for your computer, you can suck any code out even from the IDM.
Pull the damn kick panel off and check that ground wire.
i got a snap on solus,
pretty sure this scanner will pull any code it throws.
only code i get is an EPBV code.
ill check the ground tomorrow.
may just replace the whole damn thing.
Gem modules have to be re-programmed to the specific vehicle. A new one is around $350. I've seen some on ebay rebuilt, some say they are programmed. Dealers around here charge $100 to program them.
Damn Ford truck windshields leak, water runs right down into the Gem, plugin connectors get corroded.
with my PSD endeavors, i have learned to not F with it until i get data to back up my assumption.
stoped by a buddys shop today, he has the new matco scanner with wifi receiver!
sure as ****, it pulled the GEM module up and found it faulty.
so now this can be diagnosed with a scanner, just not mine.
gotta call the Ferd dealer.
