How much DCA??
gulfeagle
Central Texas
Greetings all. How many DCA units should my '94 have in the coolant? Bought some Fleetguard DCA from an International dealer and he is telling me 4 units per gallon of coolant. That's almost 5 bottles of DCA for the truck. My last IDI I bought the FORD coolant additive and they said three quarters of a bottle. What gives? I don't want any block rot for sure but I also don't want to sock 30 bux worth of DCA into my radiator needlessly. What's your opinion? Many thanks-----Gulfeagle.
troutwest66
Ricer-Roni The IDI Treat
Post Falls, Idaho
On the Fleetguard test strips you want the level to be between 1.5 and 3.0. More can damage water pump seals I've heard and less isn't enough protection. I guess the size of the bottle would be a factor. I would imagine a couple of pints or so in a fresh charge of antifreeze would be close but you really need the strips to be sure.
gulfeagle
Central Texas
Thanks troutwest. The strips I have. I just need a place to start. There must be some unit specs out there somewhere. I don't want to go through half a dozen strips till I get it right. Thanks for the reply.
yARIC008
Drives really slow
Orlando, FL
2 bottles for 8 gallons of coolant. Yeah, ford is retarded, 3/4 of a bottle won't do you any good.
