TBigLug
I Miss U Baby Girl
To leave your truck idling?
To have your truck plugged in?
Idle is ******* these engine and any diesel engine really. The biggest issue with our engines is the low oil pressure at idle. The second issue is that at idle the engine does not realy run hot enough to burn all of the fuel. Cylinder washing and wet stacking can result from extended idle periods. In order to prevent this EGTs need to be kept above 275 degrees.
As far as keeping the truck plugged in I have never heard of a limit to it. All though does get ******* the electric bill after awhile.
I might mention a few guys have rigged their cold start solenoids to a switch in the dash with a diode to prevent back feeding the other items in that circuit that come on during normal cold start.
