onetonjohn
Should I pick it up while I have the chance or pass cause I don't need another project?
Dually 4X4 CCLB trucks weren’t factory. They are all conversions. You could get 4WD, or, dual rear wheels, but not both.I've only seen two on the west coast, one was a factory option standard cab, one was an extended cab with a D50 swap and duals under it. My truck is the only dually 4x4 cclb I've seen in person or in ads.
Cab and chassis (all were RCLB, 11000 GVW to 15000 GVW)
- 4WD and 2WD DRW F350
- 2WD DRW F-Superduty
Definitely not supercabs. I worked at a shop where the owner liked to assemble that configuration from salvaged trucks.I thought they made a factory option 4x4 drw in single and extended cabs?
RegularThere is no 'box'. They are 5' or 7' cab-axle dimension. 11k gvwr max (maybe 12k?) for the f350; 14-15k for the F-superduty.
The F-superduty had a longer wheelbase available also. Probably 9' cab-axle.
