How common are F350 regular cab, cab and chassis, 4wd dually?
onetonjohn
California
Should I pick it up while I have the chance or pass cause I don't need another project?
u2slow
bilge rat
Coastal BC
They are a factory offering, unlike the dually 4x4 pickup.
IME, the longer of the 2 wheelbases is more sought-after. May cost more as a result.
KansasIDI
I hate printers
Wilsey, KS
I just bought one. There are plenty around Eastern Kansas, but few for sale. Ymmv
Around my neck of the woods, they definitely command a premium over all other configurations, except maybe crew cabs, and even then, it’s probably closer to a tie.
I've only seen two on the west coast, one was a factory option standard cab, one was an extended cab with a D50 swap and duals under it. My truck is the only dually 4x4 cclb I've seen in person or in ads.
KansasIDI
I hate printers
Wilsey, KS
Dually 4X4 CCLB trucks weren’t factory. They are all conversions. You could get 4WD, or, dual rear wheels, but not both.
Cab and chassis trucks were all DRW F350s, or F-Superduty, and all were regular cab. Plenty of conversions out there though.
The Dana 60 was available in SRW regular cabs, or crew cabs. If you wanted a SRW extended cab, it was an F250 and thus a Dana 50 if 4WD. If you wanted an extended cab (Ford called it a Super cab) F350, then it was a 2WD dually.
The Dana 60 was only available in DRW configuration in cab and chassis trucks, with the wide offset front hubs.
For reference: 1983-1994 trucks in excess of 8500 GVW
RCLB pickup
- 4WD and 2WD SRW F250 and F350
- 2WD DRW F350
ECLB pickup
- 2WD DRW F350
CCLB pickup
- 4WD and 2WD SRW F350
- 2WD DRW F350
Cab and chassis (all were regular cab, 11000 GVW to 15000 GVW)
- 4WD and 2WD DRW F350, 60” and 84” cab to axle
- 2WD DRW F-Superduty, 60”, 84”, and possibly 108” cab to axle.
Thanks to u2slow for correction on cab and chassis models.
u2slow
bilge rat
Coastal BC
Cab and chassis (all were RCLB, 11000 GVW to 15000 GVW)
There is no 'box'. They are 5' or 7' cab-axle dimension. 11k gvwr max (maybe 12k?) for the f350; 14-15k for the F-superduty.
The F-superduty had a longer wheelbase available also. Probably 9' cab-axle.
I thought they made a factory option 4x4 drw in single and extended cabs?
u2slow
bilge rat
Coastal BC
Definitely not supercabs. I worked at a shop where the owner liked to assemble that configuration from salvaged trucks.
KansasIDI
I hate printers
Wilsey, KS
Regular
Cab
Long
Bed
is what I meant. But yes, you are correct.
5’ and 7’ cab to axle F350 (I have owned one of each)
5’, 7’, and I think you’re right about the 9’ cab to axle (rollback and larger box trucks) F-Superduty (I own 2 7’ cab to axle trucks, but have seen 5’ ones. Much less common. I am not completely certain about the 9’, as I have seen 17’ and 19’ rollbacks on these trucks. So there may be two long lengths.) Some of the long frame trucks were conversions, but I’m pretty sure there were factory long frame trucks as well.
Gerhard
