Holley red pump
fsSnowboard
Greenville, SC
i think i found the reason my truck won't start. there is diesel all over the bottom of the stock fuel filter and directly below it down the side of the valve cover and block. i think i need to get a new bottom thing. (attached # 2)
also, in the attached photo, is that the fuel selector valve? if so, which hose do i tap into?
The bigger diameter hose is the fuel supply. The smaller ID is the return. The ports are also marked.
fsSnowboard
Greenville, SC
2 final questions before I start this project tomorrow.
1. for those of you with the safety shutoff switch, do i need to wire a bypass switch inside the cab for normal startups? if oil pressure is less than 7psi the pump won't run with the switch installed.
2. when removing the old fuel pump permanently, do i need to make sure the arm is at the lowest position, or just pull it out? and if so, how do i tell where the arm is when its inside?
sle2115
NRA LIFE MEMBER
Southeast Ohio
No, I have power going through the switch to my fuel pump. You do not need to apply power before cranking as you will get 7 PSI very quick and the IP seems to have enough fuel to start with anyway. My truck never turns more than 1/2 of a revolution or so and is running, well as long as I let the glow plugs cycle that is! cookoo
I just removed the bolts and pulled it off. There should be no need to do anything different unless the arm is gone/missing. If the arm is compressed as you are removing it, the tension will try to push the pump away from the engine, making it necessary to use a wrench/socket/both to crank the bolts all the way out, whereas if you can eliminate the tension on the bolts, you can probably just use an extension and socket (turn with fingers once loose instead of ratchet) which makes it a little easier. At any rate, just remove the lines and two bolts and take it off. Pretty easy other than getting to the bolts. Not sure what you are doing with your fuel lines, but remember you will have to splice the two lines at the pump together if you aren't replacing them.
fsSnowboard
Greenville, SC
i'm going to mount my pump, then cut the line and i got some 3/8 in ID fuel line to go over the outside of the old line, and my fittings are 3/8 in at the pump. then use some line clamps and clamp it down. that way i'm only cutting out maybe a foot or 2 of oem.
